You want to build a 12vdc push pull smps and get around 250W with a +-35vdc output. So lets start gathering some data. First we will assume a poor 60% efficency because of no output inductors.
250W x 1.4 = 350W input power.
Assume 14.7 volts max input.
350W / 14.7vdc = 23.8A, max primary current.
BTW, I am not perfect and i make mistakes. If anyone see’s a mistake speak up!
Hi, I noticed that this is the max primary current @ max primary voltage, like when the car is on, but if the car is off, and maybe battery is a bit low, shouldn't we calculate the
minimum primary voltage of around 11.5 to 12.1 V? In this case the current would be in the range of 30.44 to 28.93 A, allowing for a better safe margin
Thank you for all the clear explanation!
