@ MicrosiM
What do you think..? can i get full project of SMPS with IR2153?
Mhm .. Ok.. thanks..also i want to say that all project's from this site are only and strictly for my own personal satisfaction ..i will and i want to use this project's for supplying my DIY amplifiers..never for professional or commercial use..
Hi MicrosiM ,
Can you please tell me,
1. what is the time delay in seconds required for bypassing the inrush current limiting resistors in sg3525 circuit.
2. which output of the sg3525 gives the first ouput pulse
regards ani
It should be output A
Hi MicrosiM ,
Thank you for the clarification.
In the 1Kw circuit if the output A of sg3525 is given to Low In of IR2110 , on the first pulse itself the bootstrap capacitor of IR2110 will get charged. so that there will be sufficient voltage accross the boot stap capacitor when the pulse at The Hin of IR2110 arrives.
regards ani
Hi MicrosiM ,
Is it not necessary to use a Gate to source resistor for MOSFETS ?
regards ani
@ microsim
hi again, can this design with SG+IR be used for powering my servo driver for DIY CNC machine? I need something about 800-1000W for my servos, and I would really would like to throw out that bulky toroid?
stay well...
