zeus_threat
Hi everyone i'd like to detail a project that i've built here. It took me some great deal of time to put it all together, tune measure and get it to work since i have built it from scratch. Call it the zeus speaker if you want lol. It was inspired from studio monitors though my drivers are not studio grade but the performance is really good and sounds really musical for my taste
This is what it was built from:
1 X 1" Dome tweeter 8R
1X Audax 6" speaker 8R
1X LM3886 for the tweeter amp
1X Discrete amp tuned in simulation based on "Blameless Amp" for the woofer
1X PSU board with soft start + regulated +-15V output and +-35V output filtered by 4X4700uF for the amps
1X DC + relay based remote start up board
1X Speaker protection board for DC offset
1X speaker delay start based on an LM741 comparator
1X Crossover board containing: HP + LP linkwitz riley 4th 24dB/Octave, tweeter delay eq, woofer baffle step eq, LR Riley Eq to eq the woofer to ~45Hz and a Q of 0.8
All housed in a sealed + damped with cotton woll enclosure with bracing measuring h: 32.5 cm X W 20.5 cm X 32.5cm depth based on 1/4" MDF
All electronics housed in back of enclosure.
Drivers flush mounted to minimize diffaction.
I will post pictures of it i need to lift it off its stand and it weighs a ton.
Its controlled from a small buffer pre-amp \volume unit based on TL072CN Ic's with regulated LM337-317 supply with a small headphone amp and the DC to switch on the relay to power the speakers.
All pcb's were home designed and home made and all measurements (freq, woofer T/S, tuning e.t.c) wre made with speakerworkshop:http://www.audua.com/
Am planning to rebuild the pre-amp based on PGA2310 ic controlled by pic and LCD display + relay based input switching plus removed the huge EI transformer + the huge psu board and replace it with an SMPS that am trying to build here: http://www.diysmps.com/forums/showthread.php?158-Drive-signal-issues-with-half-bridge with the immense help of the great Microsim
and others
