400w mono good amplifier for general purporse!
IGBT
Switching Fanatic!
This Amplifier is intended to beat the DXBLAME into the design
Its really simple amplifier , with some parts, that sounds amazing, clean and warm
Please submit your reviews...
All files are attached, schematics, PCB files!!
If carlos dares to come here and mention any thing about it, lets see if he dares
Enjoy
  • amfican.zip
  • rms400w.rar
erhan739
İt is my everytime favourite ; best and special. thanks for sharing it will be favourite all diyers.
erhan739
it have unbeliavable tones and power capacity everytime.Let's Do and enjoy the best sound. and post your all comments!
I've found a test video load= 2 ohms feel it!
[video]http://www.livevideo.com/video/1FE01719AE314F7A812219B3843A2C67/250-rms-test.aspx[/video]
rosa
Enjoy
hi IGBT
can you share the file of this amp in pdf file coz i cannot open
the zip file my email (roseapura@gmail.com).
Thanks in advance.
rosa
erhan739
All fİles
All files attached thermal protection jpg files and pdf circuit files attached enjoy.
  • amp400.PDF
  • amp 250.pdf
  • protect.pdf
Sierra
Valve Lover!
Nice
me erhan
you have very nice projects friend
Tel me i see two version of amplifier and protection?
Dose this amplifier sounds perfect?
thanks
erhan739
first model stands 250wrms second model stands 400wrms. the protection cards working right is 3 secs delay and depends heatsink's temp 1st turnover power more temp works 3nd turnover and more heat last period and cutts relay's power. it is a good temp protector ı've ever seen. Thanks for all intersets
rosa
Nice...
thanks erhan for sharing...what is the maximum power supply for this amp? can i power this with 80vdc?
regards.
rosa
erhan739
rosa,you can't put that for it but you can replace with high voltaged driver transistors it is available, because bc556 bc547's working voltage maximum 55-60v
rosa
But using 2N5551 and 2N5401 transistor may be possible? or higher voltage transistor like MJE15033 and MJE15032?
erhan739
yes, if you use them, possiable but check transistors' datasheets pins, maybe stands 70 or 80v try it
meanman64
Enjoy
Then I must build it and compair it with my Blame ST
