engel, yes, it is possible. You have to change resistor, which is in series with two 100uF capacitors to ground. Now there is 620 ohms. You can calculate it with single formula: Uin=Uout/(1+24000/R), where Uin is input voltage, Uout is output voltage for full power and R is resistor in series of those capacitors. When you use 510 Ohm resistor input voltage will be sth. about 800mV RMS. Its better to use lower gain power amplifier and use preamp rather, because power amp with such high gain could be unstable...
