Group Buy 2KW Class-H Amplifier
cynikalX
are these still available? Any idea what a list of parts would cost (so one has an idea of total amount that would need to be spent).. even better if there's a recommended power supply (or a link to building a recommended one)
will give u special price, 30US$ for 1 set ( 2 PCBs)
mj777
Yes Sir pcb's are available, cost of the parts depends on how you want to build the amp( normal parts or high end parts). parts list and schem will be given upon purchase of the boards.
mj777
cynikalX
could you provide a ballpark figure of both end of the ranges.. e.g. what's the lowest likely cost and what's the high end likely cost please? How easy are the parts to find also? Didn't see mention on a recommended power supply (or is that part of the kit as well?)
I'm not new to electronics/soldering but far from an expert, so also wondering what the difficulty in assembling this kit would be.. thanks for making it available!
mj777
class H BOM
Hi Sir cynikalX,
Here are the list of the parts u need, this will help you decide on the parts that you will use either high end or regular parts.
mj777
P.S. Sorry for late reply really busy on my work.
  • CLASS H AMP BOM - B by MICROSIM.pdf
lavindoo
Mr ... how to know ir2117 work well ... I am building a class H amp volt dc step-up using ir2117 ... on the negative rail can not walk ...
my power on switch at main supply melt with 2kva trafo, lol i think its draw huge current, also my friend horn tweeter dead :D
mj777
my amp is near to finish after long time
after some time i manage to test my amp again, this time it is near to finish im going to fix it in a wooden case.:)
mj777
my working amp
very powerful amplifier, detailed clear sound, strong bass. I really like how it sounds.:adoration:
you will be happy how it sounds. Thanks to Microsim and Workhorse for a well design class H Amp.:w)
mj777
