I used PI Expert to design a flyback supply, 45 volts, 1 amp. When the design finishes, I get a warning to "verify design on bench and ensure BVDSS on MOSFET is below 700V".
How do I do that? I built the supply and with a 100X probe (scope ungrounded) connected across drain and source, I measure a 348 V Pk-Pk squarewave. This is with the supply putting out 45 volts with a 40 ohm 100 watt resistor load.
Do I have the scope probe connected to the correct points?
