I need a help about SG3525
dinithm
I made SMPS for a car amplifier,
but there is un expectable spike on it
this is the waveform at IDLE
1A load
heavy loads (<3A output)
this is data of my transformer
can u pleas tell me ,what is the reason of that matter.and what do I do to resettle this ,
thank you.
dinithm
the transformer that I pick from another car amplifier working perfectly instead of my transformer
so what can I do for my transformer,
thank you
ultra
Since you are using a transformer from another amp, lower the Fosc to around 50KHz and see what happens.
angellina
Redwire
Can you post your actual schematic?
I am seeing the MOSFET take a very long time to switch, about 1.5 usec
I would guess problems with the driver, looks like turn ON time is too slow, or way too much deadtime.
Your transformer calc. tool shows 2usec deadtime on 70kHz PWM which I think is too much.
Why 21AWG secondary winding for 4A? Seems a bit thin.
SG3525 can have troubles driving big mosfets, especially if you have no filter between Vc and V.
