JBL AUTO AMPLİFİER: 301.1 special edition with use @home
erhan739
Hello there, ı was finished tests about this. best works with at home or car. The original circuit's editing more power less impedance and less to carry. ı was put 2x70vdc and ı get 2x400w with this. ıt have a phase inverter and stereo mode. check this out and feel the power. it stands stable 2 ohms ;) the files are at the attachments...
  • 301.1 yeter.pdf
michelle
hi erhan
greetings thank you for this nice project but how to put in car any supply for it
thanking you
michelle
erhan739
You can make DC TO DC converter for use at the cars. you have 2 ways to make, you can use ATX pc power supply's cores without re-winding or you can wind toroidal transformer easily you can choose anyone. MY friends made succesfully, If you want i'll publish at here but ı want more interests other members.
michelle
hi erhan
greetings thank you for replying for me atx supply is good enough i am interested but i need your help to complete supply its new for me
hoping you can help out
thanking you
michelle
That looks robust erhan, Any Car SMPS for this great amplifier?
Keep the good work.
erhan739
You can put up to 2x70v, but you can put about 2x50 60v. it is already a car amplifier and good works car smps's but it must 800w or above. I'll post some car smps circuit to this.
erhan739
This amplifier from JBL car amplifier of Grand Touring 301.1 mono subwoofer amplifier. you can find easily on the net but this is re-draw model in stereo and bridgeable. if you want make and need ı'll find for you.
Sierra
Valve Lover!
Dc/dc
Hi erhan
You said you can power this using DC/DC converter.
Where i can get one power supply like that for CAR amp
erhan739
Hi erhan
sure you can check this one, ı find one about 500w for 12vdc however, no winding required! if you find ei33 core, you can done. ei33 core in the atx power supplies. you can dismount and mount this circuit non problem.
  • 500 watt DC-DC smps (mini).zip
  • smps.pdf
erhan739
Everything is done for you,members. Especially thanks for your all interests. However ı'll find toroidal car smps for all powers all voltages for all members.
Charmonix
HiFi DC-->DC +- 50V
Hi erhan739,
Very nice, I wonder to made a really Hi Quality DC -> DC Converter + 50 - 50V for use it in my mobile car home for a dedicated HiFi playback ?
Any help on this subject would be greatly appreciate,
Thnx for the answer,
erhan739
these cores from ATX power supplies. you must get correct core. you must get Eİ33 core. you can get 150-200w each core. all informations in the attachmet. (#12)
Charmonix
Hi erhan739
Please post a higher resolution SCH file so it will be possible to read the components values.
Thank You :)
Ceers
