Jbl btx 250
erhan739
Hi guys, ı've found usable scematic+pcb for your subwoofers!
It is JBL BTX 250 BAZOOKA ACTİVE SUBWOOFER's amplifier stage. My friends a bit changed original scematic and it is here now! with 30-500hz changeable sub-sonic filtered and bass boostered active cross over! Not over, i'm taking 3 step fan controller and thermal protector too! enjoy with them... All files attached... Finally ı'm taking its original filter.you've many options!
  • Desktop.rar
  • new_crossover.pdf
Lira
you can use 4558 or similar op-amps
May I ask one thing? Probably i'ts a newbie question, but which one is better to use on this amplifier? the NE5532 or the TL072? The 4558 is quiet hard to find here in Brazil.
Thanks for you attention.:D
erhan739
ne5532 is good chip but TL series are fet constructed. ı don't like also 4558 you can use if you find 5532 but you can check ıc datasheets.
rosa
hi ehran do you have schematic of your crossover..please share.
rosa
Lira
Hi friend, A friend asked me a question about that 13K resistor connected on the output, it can be changed to a 15K or a 12K? Because it's easier to find.
Thanks in advance
Lira
hi erhan have you managed to use this crossover with p.a subs and your big amp ? what did it sound like? is it 24 db or 18db ?
erhan739
i used this with L2.8 amplifier about @4 ohm 1200w and 2x18'' eihgtheensound 800w rms subwoofers.... perfect...
martha78
Trojhan
hi @erhan739 , for the continuew this, crossover is verry complex,.. can u share to me other disign for PA?,.. i need for Apex H900Teff & because I do not want to buy, but making your own because my interest in the hobby, .. thanks
erhan739
Sure... what do you want in your crossover ? i have some prototypes and i can share to you dear member.
martha78
Trojhan
thanks in advance, of your submissions will be very helpful for me. I want to and interested in the dbx xseries (dbx 324xs or the other that is easy to get components), if you please please send to my email: ugho_mdlx@yahoo.com
thanks and regards.. ;)
erhan739
Hi, if you want submissions, i can advice to you a jbl btx 250 orijinal and updated model. Or i can advice My friend's draw. You must try and feel it. İf you want, i can share here.
