LED Driver IC 51LP
smpsdiyer
Hi All,
This is my 1st post and I apologize if it is in a wrong section. Please feel free to delete or move to the right section.
I have a 9W LED bulb and it has a transistor like SOT92 IC marked as 51LP and beneath it marking F48, which is blown up.
I want to repair this and coudln't find the part nor a datasheet to see if possible to find a substitue.
Attached are few shots.
smpsdiyer
Hi Master Silvio,
Many thanks for your reply and the link.
I am not sure about this but it could be TL751LP. This is a low dropout voltage regulator
here is the link for the datasheet https://www.alldatasheet.com/datasheet-pdf/pdf/28831/TI/TL751LP.html
I got the pdf and as per page 2 the "ORDERING INFORMATION" table and the "TOP-SIDE MARKING" column, it does not include any matching markings for "51LP F48" as per the listed/below:
TL750L05C
50L05C
51L05C
750L05C
TL750L05C
50L08C
750L08C
TL751L10C
50L10C
51L10C
750L10C
50L12C
51L12C
750L12C
Since you are a master and this driver circuitry confuses me, then I need to ask isn't this circuit a buck converter so it needs a pwm ic?
I managed to find a datasheet but its in chinese and hope it helps.
http://www.radioradar.net/en/datasheets_search/Y/X/8/YX8122-ETC.pdf.html
Much appreciated.
There exist a 3 legged chip such as the TOP family like TOP221 which is used as a flyback buck converter. I am sorry to say that a chip with that name 51LP I never heard of. I guess you will be better off buying a small PSU that can power your leds. They are very cheap from E-Bay or Aliexpress.
