Maxter 3600
aldemarar
Este circuito es muy poderoso y de alto fin :cool:
debe realizar el pcb de los inyectores
  • crest[1] impreso.pdf
  • crest12[1] foto targeta.pdf
  • crest componentes.pdf
  • crest COMPLETO.pdf
michelle
hi aldemarar
greetings how many watts is this amplifier very compact pcb design what transistors in output stage
thanking you
michelle
michelle
hi aldemarar
greetings power output schematic needed compact design can you please help me
thanking you
andrew lebom
aldemarar
hi aldemarar
thanking you
andrew lebom
perdon por el idioma, no hablo ingles
el amplificador es de 3600wrms 1800wrms por canal trabaja con 70v+- y 150v+- debe utilisar transistores de potencia que soporten mas de 300vce
michelle
hi aldemarar
greetings can you please post full schematic it would be very helpful to understand it hoping you can help out so i can assemble it
thanking you
michelle
michelle
hi aldemarar
greetings output section schematic needed with step regulator schematic please can you help out
thanking you
michelle
aldemarar
ayuda para montaje
hi aldemarar
thanking you
este es el esquema con los transistores de salida, puedes usar 20 mjl 21194-3
this is the scheme with the output transistors, you can use 20 MJL 21194-3
michelle
hi aldemarar
greetings thank you for the schematic for testing can i use 2sc5200 2sa1943 in output at 70 volts dc today i will make pcb
and show you thanks for so much cooperation very grateful to you bye
thanking you
michelle
aldemarar
hi aldemarar
thanking you
michelle
si puede usar 70 voltios pero recomiendo 90 voltios sin clase H para ese transistor
michelle
hi aldemarar
greetings thanks is there a schematic for power supply step drivers for h class operation
thanking you
michelle
michelle
hi ravpreet420
greetings for power supply see H900 h class power supply in diy audio will be helpful to build maxter amp
thanking you
michelle
