Maxter 3600
CHESHTAP
2 layers-class h
Without speaker protection & power supply boards
capsighter
master3.6k PCB...
vedmitra
Thank you Mr. Capsighter for nice p.c.b. photo but if I am not wrong there is a small mistake in pos.150v side.10uf and104pf con. are to be connected afterin4007 diode they are connected to 10r res.correct me if I am wrong,though I can make p.cb. out of your photo with help of photoshop but will be gratefull if can get p.c.b. and component layout in p.d.f. thanking.
Vedmitrasharma.
vedmitra
Thanks Mr. Capsiighter for the link but same faults in the P.C.B. has somebody tried this amp.I am gona try this amp. will be thankfull if can gain some more knowledge from learned senior members who have tried this amp.
Vedmitrasharma
capsighter
This amp is tested from the original circuit... but i just add some protection base on the original circuit but if you may you can follow the original circuit of this amp... because ive never tried my PCb layout....
Best regards chinokscapsighter...
