MY 1KW SMPS Completed
Status
Not open for further replies.
Dx Hugo
Okay, ETD49 core is very good!
Let me clarify that I am here to learn! You are the master here! And I am the disciple ok?
You have mail in your personal box in this forum.
di1in
I'm a newbie here and i would be gratefull if someone could point me to a schematic and formulas for an smps project that i could do with my friends.
thanks in advance! =)
Welcome to forums.
You can check previous posts, you will find the schematic of the 1KW half bridge SMPS.
Also see attched document for more info.
SMPS-Note1 is a good starting point.
We will make that SMPS soon, so please follow up
  • SMPS-Note1.pdf
  • 2006_Design_Information.pdf
SMPS Parts
Have you got the SMPS parts? Core, IGBTs ?
di1in
Welcome to forums.
Thanks Microsim, I've subscribed th thread.
ravs
Hello Hugo.
I cant remember that you asked me for that, however
No intrested people was found into this SMPS, therefore no progress was made.
I will supply you *here* with schematic and BOM, I am glad that you are still intrested into this, this makes me happy!
I dont know if you have access to the parts.
See attached schematic for SMPS, and tel me if you can get those parts.
Also the PCB is ready for this SMPS.
hi microsim
its not that people are not interested in your smps .they do not know about this site .as you have seen
on diyaudio there is always a demand of working smps.as people come to know of this site they will show their interest too.i am also interested in making this smps.
i have couple of questions i have got etd49. could igbts can be replaced with irf450 if not then i have got
some g20n60b3d/irf g4pc50ud can anyone be used.iam also in learning mode.looking for half bridge
topology.but different books different calculations very confused.what formula did you used to calculate your
primary/sec turns.i tried marty browns,abraham l pressmams,col mclymens book.different approaches.
keep up the good work.thanks in advance.
greetings
ravs
be a vegeterian.......
hi microsim
greetings
ravs
Thanks Ravs.
In the next weeks i will put a complete informations about calculating primary turns.
On later stages will put all other details, to help every one understand whats going on, Even my self I spent long time to understand this issue, However I am using same formula in Marty brown book!
Even on the web, i couldn't find one article that tells you how to calculate turns (they all makes you confused), or even how to extract datasheets.
ravs
hi microsim
looking forward.
iam still reading different books.
ravs
be a vegeterian
Smps
Now I need to know if there is any one still interested into making this SMPS.
If yes, at lease I need to know, or some one should help me out.
Determining the power we need.
Parts availability for all those who plan to make SMPS, like
transformer they have, Mosfets, Wires available, Isolation tape.
all basic things.
In order to start the PCB, Calculating Transformer.
And much more interesting things!
Please let me know
ravs
all basic things.
Please let me know
hi MicrosiM,
yes iam still waiting .but a couple of things what about an option to add pfc .single sided pcb as it would be diy version. more easily available parts ie ir2110,2113, irfp series mosfets.ir2153 is very expensive more chances of its being fake.this smps is more meant for power amplifiers so 800-1200 watt should be the
minimum rating.over current and short circuit protection should be there.for me etd 49 is available
but for some dont.so pcb layout should have the option to use different cores ie ee/toroids.
thanks
ravs
dudaindc
Analog Ears!
all basic things.
Please let me know
Yes, still very interested but I had to move to a smaller place and most of my "lab" is in boxes in storage place a few blocks away.
Meanwhile I am reading the references you provided when I have a moment.
The $ crisis in the US is making us working more hours and earn less... not easy at the moment.
Thanks for all your efforts - lots of people admire your persistence.
Cheers,
D
ashutosh
hi ... i am new to SMPS .. my project is of a 30 Volt , 30 Ampere SMPS ..using Full Bridge ... could you send me links to application notes useful for it ... !!
Thanks .. !!
ashutosh
Hi.. I am making a 30 Volt , 30 Ampere SMPS .... using Full Bridge
I am new to SMPS ... could you please send me links to appl. notes for getting started ..... !!
Thanks ... !!
IGBT
Switching Fanatic!
Full Bridge
Thanks ... !!
Hello
Hope the attached doc, will help you out!
  • ucc3895.pdf
handrich
Hi Microsim,
I'm from Indonesia and i really interesting with smps, i have build smps with transistor (self oscilating) cause ic such Ir 2153 etc is hard to find, please teach me about smps.
I'll prepare for build new project smps,
thanks for help
CobraNet
Hi Microsim,
thanks for help
If you cant get that chip. how you will make SMPS?
Try, SG3525 and IR2110
Those are easy
I have schematic for u
handrich
@ cobranet
I will search from psu computer, usually used sg3525.
or i will buy from ebay, i have many ferrite here (rejected unit from electronic manufacture) etd 42,49 it's only USD0,5 (include wire inside hehehe).
I really appreciated if you could share schematic to me at handrich@ymail.com
will create it by schematic and i will post the result.
thanks for kindly help
IGBT
Switching Fanatic!
hai
@ cobranet
Ebay is full of IR2153D chip also, get 10 for some fun.
Status
