SMPS with PFC
res_smps
I think I have to correct this statement
Sorry Silvio,
With the presence of PFC, capacitor requirements can be smaller, I attach an excel file for PFC calculations (I downloaded from onsemi website) in post # 5
I thought the PFC frequency determined the size of the capacitor, I was wrong
from the worksheet, capacitor requirements are not determined by the PFC frequency, please check this formula (pic) below
*for the same power, the higher the output voltage the smaller the capacitor needs
res_smps
In the pfc circuit to my believe the value of the capacitor determines the hold time at load.
Check this ( I sent you mail)
Dear Silvio,
yes, that also true. Thank you for the file, I also previously shared it here (zip files) in post #2
please ignore the picture in post #41, there was an error
cbulk value is determined from the highest results from the following 2 formulas :
1) 10000*Pout/(0.01*Vripple*2*pi*Fac*Vout^2
or
2) 2000*Pout*Thold/(Vout^2-Voutmin^2)
from the formula this parameter determines the cbulk
1. Line frequency (Fac) 50/60Hz
2. Pout
3. Tholdup
4. Vout
5. Vripple
Pout and Vout appear in both formula
Marshall
About this project , i checked separately every stage , NCP1653 in Data Sheet has same conections as on this schematic only inductor everywhere is 600uH, UC3845 is simple power supply, i share schematic here, connections are good , power stage with SG3525 is also ok , but, things that i dont understand, as i know , this configuration in half bridge main transformer has 13+13 turns in primary , same number of turns also here, i know that full bridge have less windings than half brigde , maybe 2 X 7.. that its not clear, also inductor 380uH vs. 600uH !? , number of turns on transformer on aux supply !? and windings on GDT !?.. PHOTO.jpg
stewin
hi andrew . did you manage to make your smps work succesful with the pfc? please post photos and your experience on its power.
