The Best Amplifier I have ever heard
nazirdigi
hi microsim .
the diodes are bigger than in4007 am i correct?
is it fja4313,4213 outputs better than 2sc5200 and 2sa1943 numbers?
nazirdigi
hi microsim,
see the below image . there are two connections not connected.is that correct or i have to joint them.
can u share the top layer in pdf format.
Regarding the diode, you are right, its 1N5401 or 1N5408
those two connections are the input of the amplifier
FJA are better a littel than 2SA 2SC, but 2SA 2SC is robust also, you can use them
nazirdigi
thanks microsim,
i m not talking about the input connector. about the two paths. see the image.
nazirdigi
hi microsim,
i took print out of this amp, but some paths are very thin so i edited little paths.
is this correct.?
  • micSphere_PCB_2.pdf
hi microsim,
see the below image.
what is that part.?
Thats the thermal switch, to be mounted on heatsink. Normally closed
You can short it for testing.
Double check every thing before powering up.
Have you made PCB yet?
nazirdigi
hi microsim i m collecting parts from the shops and some parts not available.
so i m trying.
what thermal switch should i buy?
TS
so i m trying.
It looks similar to the one in the picture below!
When its cold, its shorted.
When reaches 100C it opens.
You will have to attach it to the heat sink when you success into your amplifier!
Good Luck!
thanks microsim,
is this thermal switches has plus minus sides and what value should i buy.
No polarity for these switches.
you can buy 80C value, withc I think its good for Amplifier.
You can leave it until you finish the amplifier.
alex mm
Hi all ,
nice amplifier but seams to be one error (shorted + rail with ground ) like in attached pic.
nazirdigi
hi microsim,
i cannot find these resistors 51ohm,510,24k,11k resistors. these are not available to buy. these are not common numbers.
so whats the solution?
hi microsim i finished the amplifier and removed the shot but . it not working properly i.e has noise and does not bias will try to upload my photos steve
Stewin
I am not sure about your problem, but some general check out will be very help full.
check transistors position, test them and make sure they are working, check soldering. This amplifier is very simple.
Tell me more information, like the protection circuit working or not, upload a video of turn on sequence + if you can record the noise in the video to hear it.
I will try to figure the problem from your information's
