Have you tried winding the 64 turn in bifilar fashion? Are you using a layer of tape between each winding. Are you leaving 4mm margin space at the bobbin cheeks? I think your winding is arching and shorting out due to the high voltage.
Are you using a snubber in the primary? any spikes in the primary will be amplified in the secondary winding and the voltage here may rise more than a 1000v. If your insulation is not correct the secondary winding may arc and short out.
When trying out the transformer put a small load on the output. This will help control any excess voltage spikes generating very high voltages. Try to never start the transformer with the secondary high voltage open.
Lastly use new enameled copper wire. see that it is in good condition. Use mylar tape for insulation and not something else.
Good luck
Good luck
