Hello everyone
I need to build a smps for a car amplifier(class D)
The amp requiers a single rail of 50v and about 6 amps .
Therefor the smps needs to deliver 300w, and it will be a classic push pull topology.
Problem is i do not know how to design the transformer, If for the turn ratios i did find some formulas(altough i do not know if they apply to push pull top) i have no ideea how to determine what the max powwer for a given core can be.
In here they use a 29mm ring core for 500w(same core for 1kw??) . In the datasheet for that core the core losses are 614 mW(112 mW/cm3).
I want to use this core(3F3 material) Will this core be able to handle continous 300w? How do i determine the max power for said core?
Thank you!
Thank you!
