badboy_6120
It depends.
The best answer would be: if you want to limit temperature rise of a winding you have to limit copper loss for that winding.
For example, if you do a test with DC current flowing through the transformer then you can find that (just an example, I'm trying to guess) it takes 8 watts to rise the temperature of the windings by +30degC. With a fan, it takes 15 watts for +30degC rise.
Then if you have just two windings you can split copper loss equally between the windings.
Taking into account pri and sec voltage, current, copper resistance and winding length (you can use MLT aka mean length per turn) you can easily calculate minimum wire area.
Thank you for your helpful answer
what awg wire do you suggest I wind the transformer with???
