I am using a new PCB design. I made a jumper to shorten the lead connecting the source pin of the high side and that didn't change anything. I also made the gate resistances larger and that didn't change anything. Thing is, it seems to work perfectly at maximum duty cycle. I can also lower the duty cycle some before things go wrong. As others said, maybe I just cannot lower it that much with the bootstrap supply. However, even though I can lower the duty cycle some, it doesn't effect the output voltage. I'm thinking this could be because I don't have a large enough load, is this correct?
Brady
If you have updated your schematic and board design, could you please upload the current version of the circuit you are using?
The lowest duty-cycle that you can use will depend on the size of your bootstrap capacitors, the current that your VCC can supply, how fast the bootstrap diode can begin conducting when the LS switch turns on, and the amount of gate charge that your FETs require to fully turn on. The IR2110 can be kind of tricky to get right, but they do work fairly well when properly setup.
The no load/light load condition is most likely correct. Your schematic shows a large inductor and capacitors on the output rails so a light load would require very little duty-cycle to maintain the output voltage after the caps are initially charged up.
I'm using a 100x probe. I actually noticed that it did have an affect on the performance. When I removed the probe there was no screeching sound as there was when the problem occurs. The problem probably does come down to the bootstrap supply as you said.
Brady
Probing the HS Fet with a 100x probe is an acceptable method of doing so, just make sure that you are hooking the ground clip of the scope probe to an EARTH referenced point so you don't create a ground loop back to the mains. Honestly, based on the one schematic that you posted, you should be able to probe the HS Fet without using the probe's ground clip at all. Obviously the waveform will have the positive and negative bus voltage riding with it, but you'll at least be able to see the shape of the waveform.
Also, if your power supply is making screeching sounds with the probe connected to the HS, then either the probe is connected improperly and it's causing the transformer to saturate, or the capacitance of the probe is loading the circuit and causing osculations. Usually screeching sounds coming from a transformer is due to saturation.
Also, what type of diodes are you using for your gate discharge diodes (D3 & D4) and your bootstrap diode (D5)?
It could be that you are not loading enough until the voltage starts to decrease. You did not say what is the current drain on the output is. you can try a 100 watt bulb (110v) on the two outputs hooked in series. At 60v from your output does not give so much current I guess it will be around 0.8 amps or so. This will be enough for the first test. You can also try a car bulb rated 24v 21watts and load one end of your double output at a time. These are cheap to buy.
I guess Brad was right in what he said about a bootstrap driven high side, as later yesterday I was reading Tahmid's Blog and the same things more or less was said having an IR2110 driving a regulated output. I guess it would be needing a separate supply so that you can isolate the high side VB pin and ground referenced to the mid point VS. One other thing that I noticed was that Tahmid when using the IR2110 powers the VDD pin 9 with 5v taken from the 12v regulator with a 7805 chip. I don't really know the purpose but its done like this for some reason Maybe Brad can explain why. It may driving this pin separately make things run smoother without much distortion on the output waveform.
VDD (Pin 9) is the logic side supply. This can be supplied anywhere between about 3.3V and VCC. The VDD supply voltage basically just sets the voltage threshold for the LIN/HIN pins (On is about 60% of VDD, Off is about 40% of VDD with about a 20% hysteresis in between). VDD can be connected to the VCC supply with no problems.
The easiest explanation I can give is this:
Say you are using an IR2110 to drive a set of IGBTs that require a 15V gate drive voltage, but you are using a 3.3V microcontroller to generate the PWM signals. The VCC pin can be supplied with 15V and the VB supply can be bootstrapped with the same 15 volts which will drive the gates. On the other side, you can supply the VDD pin with the same 3.3V used to power the microcontroller so that the LIN/HIN pins can be properly triggered by the 3.3V outputs of the micro. The main thing to remember when doing this is that the VSS and COM pins should be at the same potential as everything is internally referenced to COM. The datasheet says that VSS may be +/-5V from COM, but I don't see any reason for that and I'd keep the both at the same potential.
