High End 100W Class AB Amplifier
Sierra
Valve Lover!
I found it helpfull to share!
A very nice amplifier, with protection on board!
Technical parameters:
Supply voltage: max. + / - 45V
Output power: max. 120W/4R
Frequency response: 15 to 100 000Hz/-3dB
Harmonic Distortion: 0.1% for 100W/1kHz; 0.011% at 100W/10kHz
Intermodulation distortion: 0.31% at 80W / 80 +7 kHz
Input sensitivity: approx. 0.55 V
Current protection: 2x4A fast fuses
Sensitivity of one-way protection: + /-2V
Delayed connect the speakers: approx. 1.5 sec
Speed during SR: 13V/us
Min. impedance: 4R
PCB dimensions: 11x11cm
I wish to see some intrest into this easy amplifier!!
* I have included ZIP file for all files for high resolution.
  • 100WOsadenie.pdf
  • 100WDPS.pdf
  • 100WAB.zip
erhan739
JAKUB_G, we want see your all other projects to here we too glad, your amps pretty good. And take a look my projects ;) enjoy!
Corvett
100KHz?
Is that true? why do i need the 100KHZ for in audio, the range is 20 ~ 20KHZ
Please explain
JAKUB_G
Yes It is true. It doesn't mean that when you don't listen the ultrasonic frequencies that you don't perceive it. In general, when band width is wider, slew rate grows too...
It bounce in the elocution of high band.
radio
Hi JAKUB_G!
Jacub, amplifier is very good!
I want to ask a few questions:
I have the power supply UCC = + / -36Vdc/400W. Can I use this power supply for the amplifier or your need some changes?
Your turtorijal (you topic) for this amplifier can be eaten in English or Serbian?
Where is schematic power supply for this amplifier?
Where entry is associated AC (see scheme)?
Is you have to give TOP PCB combined with the last part (for example, see TOP_PARTS)?
Tanks and cheers
  • TOP_PARTS.pdf
radio
Jakub, and I add this question and more will not bother!
Is this amplifier can be processed with the output MOSFETs IRFP240/IRFP9240?
Thanks and cheers
