Hi there. I have always been told that traditionel power supplies with huge transformers and large electrolytic bridges is much more Space consuming than a smps, also it is much more difficult to regulate when having large voltage or current outputs compared to smps.
So when i was going to replace a power supply we already got in my Company, I started to do a smps. and the clever people killed my idea pretty fast, then after some reconsiddering I did attempt number 2 and it two was killed before seeing the light.
Now I ended up with 2 question (actually a lot, but some follows the answer to those two).
1 : how to figure out what core is best and most usefull for a specific smps ?
2 : This is a stupid non good smps (according to others), but is it realy that bad ? and if, then why.
View attachment smps.pdf
Some people says it would be much smarter to do this with a primary regulated smps but I have not seen any one yet with a large output voltage span, and I need from 24V to 130V @ 3A. Now back to the comment on sizes. those i have spoken with claims it is impossible to do a 420W smps on 100mm*100mm PCB space, why should that be so impossible. Our traditional only takes 100mm*150mm PCB space.
If the one in the attachment is not good. Could any one guide me to a schematic, that I could use as a start. I need a supply that has :
Universal input : 85Vac - 265Vac
1 or multiple outputs for coverring : 24Vdc - 130Vdc
Current output unaffected by output Voltage : 3Amp
Thanks in advance
Sincerely
Klavs Rommedahl.
Thanks in advance
Sincerely
Klavs Rommedahl.
