Hi,
Specific for your aplication you will have to do it by yourself, but i can help. First you will have to use a opamp like ne5532, than calculate the frequency you want on each block(on block for flat, one for bass and one for high), don't forget to put a buffer on the first stage, you can use trimpots or fixed resistor and some bottons to activate what you want on the circuit.
The schematic will be like this (this one is a crossover, but you can put a buffer on the input and join all the outputs by another buffer.
Here is the buffer
Here is a nice calculator for you to start:
esp-lr13.exe
Hope this helps
