The main transformer which can be seen integrated with the mosfets may be wound on a standard 90 by 140mm^2 ferrite bobbin core assembly.
The primary side winding consists of 40 turns of 0.6mm super enameled copper wire. Remember to stop after 20 turns, put an insulation layer with an insulation tape and wind the secondary winding, once the secondary is wound, insulate it again and continue with the remaining 20 turns over it. Meaning the secondary winding gets sandwiched between the primary 20 + 20 turns. The center tap of this 20+20 may be connected with the body of the SMPS for an improved stabilization and cleaner outputs in terms of ripples or buzzing interferences.
The secondary consists of a center tapped 14 x 2nos turns made by winding 0.6mm super enameled copper wire.
The input and output filter coils may be wound on ferrite torroidal cores. The paired winding must be wound on the same individual torroidal cores using 0.6mm super enameled copper wire with 25 turns on each arm of the relevant supply terminals.
BR, Microchip Sound Forge
