prawncracker
Hey all! first post!
Getting into this SMPS thing guys and i kinda need help on my first build...
its just a small and simple 13.8v forward converter based on a NCP1200, a UC38xx-ish operating at 60khz.
i think imma use this for charging some backup SLA batteries. core is rewound from an old 9Wish commercial psu.
i built the SMPS fine but i need around 500mA current limit. [around 7W]
the NCP pin3 is current sense input [sensed via source resistance] compared with an internal 1v ref and says to have L.E.B [leading edge blanking]
at 320VDC input, its around 22mA at the primary and a MOSFET source resistance of around 47ohms if my knowledge is sufficient.
the SMPS works fine without the MOSFET source R but when put with 47ohms the output votlage drops to around 6.5V and the LED pulses or dims at one-second intervals. the voltage seems to drop to around 4v and then up to 6.5v but my DMM cant follow fast enough i guess...
i use a 1-2.2ohm R for MOSFET source and it works fine. next value 18ohms then i get pulsing output.
from the MOSFET source R i tried connecting RC lowpass 680ohm + 1nF cap for a 240khz knee/ramp but no avail. what could be wrong?
also id like to shoot these few questions...
currently the voltage feedback is the typical TL431 + EC817 can i use a transistor instead of the TL431? from what i read, a simple R+zener+opto series is not good at regulation.
thank you for your responses and looking forward to more SMPS activities.
