Hi Silvio
In the last time I rewound the transformer and here are the results:
As a load I used 7 series of 0.47 Ohm resistor dipped in a glass of water.
Without the output choke I got 34V on the resistor which gives 350W and 10.3A but that is not the result with the 320VDC power supply. The autotransformator I had set for some 200VAC ie it still lacked 30VAC is the nominal inverter power supply.
Increasing the voltage caused the transformer to squeak even though I laid a thin layer of cyanoacrylate on the sides of the core (not between the cores).
Also, after the waveforms on the oscilloscope, it was evident that weird pins appeared and overall the course was crazy and hopping. Unfortunately I do not have a photo.
I know I should test at nominal mains power, eg by bulb in series, but with these powers I was more comfortable using autotransformer.
The next test I did with the 10uH output choke and I got the maximum power of 204W, 26V and 7.85A when the inverter was powered by 320VDC
The chart below[transformer ]:
http://fotowrzut.pl/SI6D0MCU9W
Since the core does not want to move anymore like 350W it is not a problem with too large 0.2T induction? Many people on the Internet recommend 0.14T or 0.15T
Silvio you met with the winding of the primary winding, which consists of two parts but they are connected in parallel and not in series as you suggested me a few earlier?
In the book Power Supply Cookbook 2nd edition Marty Brown is shown. The primary windings have an appropriate number of coils (calculated value) and are connected in parallel.
Why in the ATX snubber computer power supply is at the transformer and not at the transistors?
