SMPS for L15D (~300W, +-50V DC)
Diluvian
Hello everyone,
I'm a bit overwhelmed with the contents of this forum, so my first try now is to ask you :UP:
In the far future I want to build a new Amp with the L15D or L25D Amp, are there any finishes circuits/shemes (tested/approved) which I can use as (dual voltage) power supply (+-50V)? Maybe you have commercial boards I can already buy?
Maybe I want to use two of the Amps so if there is a sheme/circuit for ~600W load would be nice, too.
Thanks so far.
Diluvian
tanju
Hi, there are no finished schematic diagrams available with me right now. I have the diagram of an output filter using L25D. For loads up to ~600W you can use two amps and connect them in parallel simply so that they can share the load simply.
