http://nptel.iitm.ac.in/courses/Web... Electronics/PDF/L-23(DP)(PE) ((EE)NPTEL).pdf
Middle of page 12.
In case the inductor current becomes discontinuous
the linearity between switch duty ratio and output voltage is lost and the output-voltage controller
circuit, which is often designed using linear control theory, is not able to maintain the desired
quality of output voltage. Hence filter inductor should be chosen to be sufficiently large such that
under expected range of load current variation, the inductor current remains continuous. In many
cases the minimum value of load current may not be specified or may be too low. If the load
connected to the output is very light or if there is no load, the inductor current will not remain
continuous. Hence, as a thumb rule, the filter inductor size may be chosen such that the inductor
current remains continuous for more than 10% of the rated load current. At 10% of the load, the
inductor current may be assumed to be just continuous. This gives a basis for choosing the
inductor value as detailed below:
Middle of page 12.
