The best amplifier i have ever listened too..i am glad to present you the Dx Blame
destroyer x
Compulsive builder
Build a Dx amplifier folks....alike a 50 brazilians did..and a lot of strangers too
Carlos[video=youtube;eDXIZvPFp1I]http://www.youtube.com/watch?v=eDXIZvPFp1I[/video]
gchim
HI friends.
i've a question, that i guess a lot of diyers have.
eu tenho uma questão, que eu acho que muitos diyers tem.
how is the kind of wire that is the best of to use between power supply and amplifier, also amplifiers to transistors, that are mounted in heatsink outside from amplifier?
qie tipo de cabo é o melhor para usar entre a fonte de alimentação e amplificador, também entre amplificadores para os transistores, que sao montados no dissipador fora do amplificador?
and talking about this, would it be interesting shield this wires ?
e falando nisto, seria interessante blindar estes cabos?
hugs
destroyer x
Compulsive builder
Resistance is very small..also currents are not that big that needs cables thicker than a telephone wiring.
These things are myths created by the ones wants to sell you their stuff dear Gustaff..... all lies..only to make you buy expensive golden cables.
Use the cable, or wire, you have at hand....and ask the ones use to say these things to you to study a little bit more instead to spread myths all around.
To shield is alway a good idea but also you will produce a huge current of noises going to your chassis if it is grounded and receiving the shield..and this is not very good too..also shielding is coaxial and you can have shorts because of defective wire insulation in between the shield and inner conductor.
The place people is saying this... a forum...is a desert of knowledge you should avoid, not to polute your mind with these kind of doubts.
Carlos
The party is almos starting...
The guests to the party arrived ...
The components ...
Chegaram convidados para a festa...
Os componentes...
Now the only missing components are the silver mica capacitors, inductors wire, the transformer and others components such as connectors, cabinet ...
But the party will start ...
Fun for a few weeks ...
Agora me faltam os capacitores de mica prateada, fio para fazer os indutores, o transformador e outros, como conectores, gabinete...
Mas a festa vai começar...
Diversão para algumas semanas...
Mauricio
destroyer x
Compulsive builder
I see you will be happy next days buiding.... this is delicious.
Vejo que vais ficar feliz nos proximos dias...e isso é delicioso
Carlos
niss_man
Pioneer Amp Converted to Beautiful Blameless
Hi Carlos
I have now finished my third Blame amplifier. The ST. This used to be a pioneer surround 5 channel amplifier. The pioneer chip amplifiers were removed. Re-used some pioneer 0.22 5w resistors. Made up a couple of Blame ST's and installed in double decker configuration. Had to connect power to the old ******board to get the lcd display to function properly.
I originally was using the old pioneer pre-amp section to power the blame amps and also I could use the treble/bass functions from the old system as well. I found this to sound like **** and I wouldn't recomend anyone to connect the Blame to a pre amp. Maybe a good quality pre-amp may sound nice?
So I bypassed the preamp section and conected the Blame amps to the input changer relay(actually a IC chip). Now it sounds as it should, and I can still change inputs via the dial on the front, including tuner input.
I recomend this to anyone who has an old amplifier spare. Turn an old crappy amp into a beautiful sounding one whilst gaining the advantages of a tuner and also less parts to buy.
This Amp is now going to be given to my father so he can finally enjoy some quality. Just have to find some good speakers to match.
destroyer x
Compulsive builder
Excelent work Simon.... very good.
Your daddy will be happy with that gift..finally he will have real audio quality in his home.
What speaker brand will you choose?
Carlos
niss_man
I have just started to look in local newspapers and 2nd hand on ebay. I would like to get some nice British or German made speakers for a good price so that Dad can have a budget audiophile system.
Simon
mauriciofc
Tenho que agradecer ao tio Carlos e ao Miguel Nabuco por me proporcionar tamanha satisfação no mundo DIY. Ontem a noite consegui terminar a montagem de 1 canal do meu Blame ST e só tenho mesmo que concordar com todos os comentários sobre ele: totalmente silencioso, sem aquele puff ao ligar. Não pude testá-lo completamente pois também vou ter que montar o pré do Nabuco pois minhas fontes de áudio não dão mais que 200 milivolts na saída. Agora tenho que terminar o outro canal e terminar o pré do Nabuco. Muito obrigado Carlos e Nabuco pela satisfação do mundo DIY.
I have to thanks uncle Carlos e Miguel Nabuco for satisfaction on DIY world. Last night I finished 1 channel of my Blame ST e only have to complain with the others opinions: silencious and without that puff on power on. I can´t test completely because my audio sources only gave me 200 milivolts. Now I have to finish the other channel and the preamplifier from Nabuco. Thank you Carlos and Nabuco for the satisfaction of DIY world.
Sempre me desculpem pelo péssimo ingles.
Always forgive me for the bad english.
Mauricio.
destroyer x
Compulsive builder
Thank you by your kind words MauricioFc... very nice from you.... i am happy you said that appreciated.
Carlos
destroyer x
Compulsive builder
[video=youtube;37XIN4NZx4c]http://www.youtube.com/watch?v=37XIN4NZx4c[/video]I have reduced power in my Dx Blame unit used for computer audio monitoring..... i have the need to steal the big heatsinks the unit was using...... so they where removed from my PC amplifier and power was reduced in order to operate with the tiny heatsinks.
Video will show you what i mean:
destroyer x
Compulsive builder
Cool Dude Clem, one of the best Youtube show man is going to build the Dx Blame ST amplifier.[video=youtube;8Tcu6yDl61U]http://www.youtube.com/watch?v=8Tcu6yDl61U&feature=feedu[/video]
destroyer x
Compulsive builder
I have made something to my own use.... i gave the name Dx Blame ST - home edition
And the video about the stuff is attached here.
Also a speaker i was talking about had its picture attached.
Carlos[video=youtube;kzOJ2MBJhOQ]http://www.youtube.com/watch?v=kzOJ2MBJhOQ[/video]
destroyer x
Compulsive builder
Modifications in the Dx Blame ST, the home edition, was installed and some of then...
unstalled immediatelly....the modifications you can see in the last post video[video=youtube;C8QvgUAct_c]http://www.youtube.com/watch?v=C8QvgUAct_c[/video] was made...but the colector resistance was supressed...no good sonics...also the input 47uf was reduced to standard because blurred the bass.... the rail voltage step down regulator was installed and video shows.
Carlos
destroyer x
Compulsive builder
Put some enjoyment in your life...build a Dx Blame St amplifier
I am sure you will feel good listening at it.
Carlos
destroyer x
Compulsive builder
Passive filter rocks too.... listen and check your prejudices about
Yeah!.... this rocks too!
Carlos[video=youtube;bKW2RDMZ7KY]http://www.youtube.com/watch?v=bKW2RDMZ7KY[/video]
destroyer x
Compulsive builder
My Dx Blame ST, the home edition, with some modifications i have made in order to...
match some personnal needs..i am not suggesting people to do this way..... i am just showing (in portuguese from Brasil) brazilians what i have done.
Minha edição pessoal, minha edição doméstica, caseira, particular, do Dx Blame ST..... eu reduzi a potencia para atender a minha necessidade...video em português para meus amigos Brazucas.
Carlos[video=youtube;pL24odxcW14]http://www.youtube.com/watch?v=pL24odxcW14[/video]
