First, if the 150k blew up, you probably made a mistake choosing them, they might be like 15k or even worse.
Have you checked the primary of T2? You can reverse it for trying.
Put a resistor and a led on the output of your transformer, I had lots of problems to measure the output frequency with multimeters. (Analogic works fine)
As soon as I finish my tests to 100% I'll post my pcb.
Transistors probably need to be changed too, you can test them before.that maybe true but i cant confirm since they are charred:ambivalence:. so if i change them in for another high wattage ones, should the circuit just work as fine ? or should i too change the transistors, assuming that they have been damaged?
if that doesnot work then ill reverse the primary as you suggested. and i did try using a filament lamp at the end of the output just to see if anything il happen, however it didnot light up what so ever. ill look forward for your design then
thanks in advance
any of you gentelmen*
i also didnot use the input caps or the filter at the beginning of the mains input- i just thought they were slightly not that detrimental since most of the filtering is done on the rectifier end any was- instead the live connected to the fuse which connected to one pin of the input, the other pin of the cap is connected to the neutral. the cap is in parallel to the ac input line of the rectifier.it'd be really awesome if someone would be able to guide me step by step as to what i should do to fix it. i have went 5 times over this thread and tried my best to understand what it is that is going on but i donot seem to find that my problem has been mentioned before.
thanks a alot again
alrighty good news is no explosions, yaaaaay!! bad news is no output on the ee35. as soon as i plug the circuit in the 100w lamp lights up then quickly fades away, which is good....i think ( well better than fireworks afterall lol ). any ideas as to how i could fix this?
i can't really thank you all enough for the awesome support you gave me thanx alot
alright update here so i somewhat fixed it but as always there has to be something that is not right.i can hear the transformer producing a tak tak tak voice which deacreases in volume when i add a load in the secondary. there is an output current on the secondary however when i tried connecting a 5 watt light bulb across the secondary, it doesnot light up i only get small sparks upon touching the terminals. the voltage across the primary is 360V even though my input for the circuit is 230 V. i tried switching the feedback winding same thing no change at all.
thanks alot again in advance
alright update here so i somewhat fixed it but as always there has to be something that is not right.i can hear the transformer producing a tak tak tak voice which decreases in volume when i add a load in the secondary. there is an output current on the secondary however when i tried connecting a 5 watt light bulb across the secondary, it doesnot light up i only get small sparks upon touching the terminals. the voltage across the primary is 360V even though my input for the circuit is 230 V. i tried switching the feedback winding same thing no change at all.i am aware that a similar issue to this has been at post #46 however there doesnot seem to be adequate an explanation as to how i can fix it
What about the trafo getting very hot without load? High or low frequency?
