0-50V 0-10A Variable SMPS
Fethiyeli
I have designed adjustable output voltage and curent SMPS having 500W output. I would like to share circuit schematic since there are many experienced people in SMPS and power electronics in this forum. Do you have any suggestion about this circuit ? or Do you see any critical fault ? This project may help to people who want to build a project something like this.
I have calculated the components value according to some power electronics and transformer textbooks.
http://www.imgim.com/6567inciz1850835.jpg
Dr pepper
I'd like to have a look at that, but the link is broken.
I found a few other forum entries too, they are broken also.
KX36
The link worked for me but the writing is lost in the JPEG compression so I can't see any component values. 2 switch forward makes sense and you might not need the primary side snubbers. Is it secondary side control with gate drive and current sense transformers uprated for primary to secondary isolation?
