Read carefully lots of mistakes, i marked them but left them in for people to learn.
For wire sizes lets work in inches and AWG because i do not have the metric formulas. When we are done then it is easy to convert to metric.
After you have the wire currents you need to know what the skin depth is for 75khz.
Skin depth in mils = 2837 / square root of f in hz = 2837 / sqr root of 75,000 = 10.359 mils = .01359" This is the skin depth for 75,000 hz, best case you use this for the wire diameter for the primary. .01359" is close to 27awg = 201cm ( cm = circular mils).
For the secondary because it is between 2 primary’s you can go 2 x skin depth. So 2 x .01359" = .02072" = 24awg = 404cm.
Primary current 9.28A x 150cm/a = 1,392cm needed. We want to use 27awg = 201cm.
1,392cm / 201cm = 6.9 strands of wire.
7 strands x .01359" x 14 pri turns = 1.33"
We have 24mm of winding width = .944"
It don't fit!
We need at least 150cm/A so we have to sacrifice skin depth to make our winding’s fit.
I will just pick a bigger wire size a few gauges up and try again.
25awg = 320cm = .0179"
1,392cm needed / 320cm = 4.35 strands. Lets call it 4 strands and see were we are.
4 strands x .0179" x 14 pri turns = 1.0024"
1.0024" - .944" of winding width = .0584" = 1.48mm to wide. Lets see what the next size wire brings us.
24awg = 404cm = .0201"
1,392cm needed / 404cm = 3.45 strands. If we go to 4 strands we will be worse than 25awg for width. But 3 strands is a little short on current. Lets try next gauge.
23awg = 509cm = .0226"
1,392cm needed / 509cm = 2.7 strands. Try 3 strands.
3 strands x .0226" x 14 pri turns = .9492" BINGO!
.9492" - .944" = .0052" = .131mm to wide / 2 for each side. This is close enough.
OOPS, i made a mistake. I used the diameter for bare wire. Magnet wire usually adds .002" to the diameter. This will add up fast. OK i looked up the diameter of 23awg heavy build magnet wire = 0.0249“
3 strands x .0249" x 14 pri turns = 1.0458" To big again.
22awg = 642cm = 0.0276" heavy magnet wire.
1,392cm needed / 642cm = 2.16 strands.
2 strands x .0276" x 14 pri turns = .7728" And guess what. MORE MISTAKES. I am leaving my mistakes in here so all can learn from them.
I am using the wrong number of primary winding’s. In a few posts above i calculated 13.33 primary turns and decided to try 14 turns. That is the total number of primary turns so we need 7 + 7 turns wired in series. GRRRR.
OK lets start over. Best case wire is 27awg.
7 strands x 0.0161" heavy magnet wire x 7 pri turns = .7889"
We have 24mm of winding width = .944" - .7889 = .155" short
It is best to fill up all layers all the way across to give you the best coupling so we will try keeping the same number of strands but using the next size wire.
26awg = 254cm = 0.0178" heavy magnet wire.
7 strands x 0.0178" heavy magnet wire x 7 pri turns = .8722"
We have 24mm of winding width = .944" - .8722" = .0718" to short = 1.824mm, not to bad but lets try next wire.
figure out were our cm/A is.
7 strands x 254cm = 1,778cm
1,778cm / 9.28A primary = 191cm, nice, better than our 150cm/A minimum.
25awg = 320cm = 0.0199" heavy magnet wire
7 strands x 0.0199" heavy magnet wire x 7 pri turns = .9751"
.9751" - .944 winding width = .0311" = .79mm to long
7 strands x 320cm = 2,240cm
2,240cm / 9.28A primary = 241cm, nice, better than our 150cm/A minimum.
I think the 26awg is the best choice in this example for the primary. Now work it out with the metric wire you can buy. And see if you can get better.
For the secondary you will have 2 winding’s of 8+8 or 9+9 depending on how it works out. Each secondary layer should use up the full winding width like the primary did.
