First one gives you an easy way to use voltage doubler and run from 110/120V mains. Second one doesn't.hi,
can someone explain me what is the difference of this circuit, advantage or disadvantage?
thank you
which document did you refer to?At the ST document about LLC at page 64 this splitted config is explained a bit better.
i agree with you, mass product prefer using first circuit.First one gives you an easy way to use voltage doubler and run from 110/120V mains. Second one doesn't.
There is also minor difference on peak currents through caps but I think it's kind of negligible.
Nope, these circuits are pretty much equivalent.is there any probability of voltage imbalance with circuit number 2?
You can follow star-delta transform and calculate exact equivalent. For example for one 470uf bulk cap and a capacitor divider made of two 1uf caps the equivalent would be 941uf bulk caps in series + 2uf cap.
Hello "Jagd.Panther"
the problem with protection (at startup) is from output caps
Should I use the same method as Input caps for it??? (use Resistors bypassed by timed relay) or is there better solution???
Please post actual schematic you use (with all of the changes you've ever made)
In the current board I have 3x680uf on each rail of primary and 3x1000uf on each rail of secondary, but in my pcb I'm going to put 4x680uf and 4 or 5x1000ufSo you have 1500uF bulk caps on the pirmary side and 3000 uF per rail on the secondary side, right?
a dual contacts 12V relay with 278 ohms winding resistanceWhat relay do you use? Voltage/winding resistance?
I did that with no luck (same result)Did you try to change C16 to 46uF?
I use 4 x 3.9 ohms /10W resistors in seriesChange R1 to 15 ohm (connect 33ohm resistor in parallel)?
So with 47uF softstart cap and 4x3.9 ohm softsart resistor the SMPS starts without load but fails to do that with load?I use 4 x 3.9 ohms /10W resistors in series
now with no load the smps starts normally but not with load
Soft start circuit based on 555 timer like the one you use has no feedback whatsoever. I suggest using circuit like the one in the attachment. It works with SMPS and with conventional (linear) power supplies.
Is the electrolytic cap 4700uf ????
it's 470uf
