Hi everyone.
First off thanks for the great information, awesome projects and the skilled members on this site. Especially Microsim, ludo3232, norazmi and stewin. I learned alot from here and built my first successful 1kw smps of mine . I used microsims knowledge, norazmi's schematics of 1kw half bridge self oscillating smps and other members help and built it.
After some modifications for my needs, i can say its good for me and want to share it on here for other people to use and develop further. This project doesnt have an output inductor and lt gives an unregulated outpuf which is ok for a 900 watt ucd style class d module.
I used ETD49 core on that project, EI16 for oscillating at 100khz, 4xirfp460 and 4xmur1560 diodes.
My one turn of secondary winding produces 6.2 volts.
But now for a friend of mine, I should make an smps which can produce only 5v 20amp average and 40amps at peak from 220AC line.
1- Should I go with half bridge self oscillated unregulated output project which I find succesful
2- If yes I would like to use etd39 for the core as etd49 is too much for 5v x 40amps ?
3- I tried to get 5v output from my already built 1kw smps but because of sec. 1 turn is 6.2 volts for 5volt output i should do only 0.5 turn. When load begins to increase, output voltage drops from 5v to 1.5v at 7 amp load of dc brussless motor. Is this because of too short 0.5 turn of sec coil?
4- What is the true way for getting constant 5v even at 35-40 amps ?
Thanks everyone !
Thanks everyone !
