twenglish1
I took a break for a while on designing my switch mode plasma cutter/welder, I have been doing a lot of reading and research on the subject and revised my design, I will be using two half bridge igbt modules configured in a full bridge setup, the modules are rated at 150 amps continuous at 1000volts, I decided to go with the EE80 cores, how much power can they handle? I have 8 pairs so paralleling them is an option, however before I get into transformer design I would like to perfect the IGBT drive circuitry and the inverter portion of the design which smps driver ic would you recommend using? The input voltage to the inverter will be about 330vdc, I have some large capacitors for the initial rectifier stage, I have 6 890uF 400 volt capacitors and 3 3300uF 400v capacitors, also have lots of spare igbt modules that I hopefully won't need. Anyway I am in need of some pointers as to where I should start in designing the full bridge driver, gate drive transformer and also I understand the dangers involved, safety pointers are always welcomed but I don't want to be told it can't be done and to not do it
