OK, yes we have a communications problem here.
Why are you skipping the information that I am posting for you ?
How come an 8 * 0.3mm wire will burn with 4A current ?
I told you before that the transformer tested with just one 12V secondary ran cool at full 4A load for hours.
I think that you are going too fast and you are skipping lots of information that I've been uploading for you to evaluate.
Definitely you are not reading all the material that I can clearly see in the thread index (upper part ), going thread by thread.
Everything you have been asking is there.
For example:
1. you asked for the kind of materials we are using - I replied in detail with a complete manual in PDF format
2. you asked for the transformer calculation - I replied to you with primary and secondary winding details, number of turns, number of wires.
3. you asked about the output inductor - I replied with the inductance of the 4 inductors and winding details
4. you asked about the core used in this transformer - I replied that was ER35/22/11 TDK/EPCOS, and picture of the forms and ferrites, permeability figure, N27 material
5. you advised that a regulated SMPS was needed for 4 secondaries, I replied twice (one quoting your text) that this must be a regulated SMPS and the reason why I am NOT closing the loop yet
6. at least 3 times you asked about the transformer calculation and I uploaded at least 3 times the output screen of the program that I am using, with ALL the input parameters, voltages, currents, frequency, core, etc, and the outpit, which includes power rating of the core, power used, winding info for the primary, n turns, number of multifilar wires and diameter, same for all the secondaries, and all the inductance values for the 4 output filters, all in one single screen.
To get things in order, I suggest then you make on question and I give an answer to that question if you agree.
I catched you last post in my cell phone by my bed and, as I don't like to disappoint you, I got up for giving you a reply. If you don't mind I will get back to bed, it is 2 am here.
Thank you and kind regards
