@ microsim hi, i need 35olts @ 20amps from etd49 with 50khz freq, 310v input, what will be the pri sec turns and wire dia?
thanks
@DJleco
bro it worked 2 to 3 times when i turned it on and off..... 300Vdc to 33.2Vdc ........but then on the fourth time one of the high side MOSFET explodes ..
can i replace IRFP460 with IRFPG50 may be that will work?.....i will not drain 15 amp of current from the secondary side ..... its just a final year project ....i can show this without heavy load.....will IRFPG50 work?
in addition what could have gone wrong this time any guess?????
if even using IRFPG50 wont work i will definitely kill myself
@microsim
sir,
i made it on veroboards with long wires hanging here and there ... mean from IR2110 to MOSFETS gates etc.......a complete mess
vero 1 for offline 200 to 310Vdc
vero 2 for SG3525 and IR2110
vero 3 MOSFETS ..ETD49 bridge caps inductor....
sir i will replace IRFP460 with IRFPG50 tomorrow ....and will tell you the result....
