As i read my post i cannot understand either
I try better....
so i have 3 bulbs which draw 10 amps at 13v each one of them.
i connect one of them as load on smps.
the current is 10 amps....
i regulate the current through pin 8 and my comparator to 9 amps... which means voltage is falling...
then i connect one more bulb ..the current goes to 10 amps overall and the voltage goes more down...
and with all 3 bulbs connected i get 12-13 amps overall (otherwise it should be 30 amps and no voltage drop).
So till now the accuracy of current regulation is 10%...
even if i short circuit the output the current stays at 13 amps....no more....but the smps tends to switch off.
This is good for a hho cell to be stabilized....as i said when the temperature goes up the current draw by cell
goes really..high..
so the cell acts as current load..no matter the voltage is applied...means that if a cell draws 15 amps the voltage
would be 6-7-8-9 volts....it depends of the resistance of the mixture (water and kaoh) inside...
i hope it is more clear now....
Niko
