^rooker
I'm evaluating the possibility of combining standard, hi-watts ATX PSUs to form a redundant power supply to drive a harddisk storage server with 45 HDDs.
The reason for that is, that all "professional" storage/server chassis for such a use-case have proprietary, non-standard form-factors (and pinouts) of their PSU modules. I'm looking for a power supply solution which can be kept alive by using standard, replaceable, documented hardware.
How much effort could that be?
The design is based on version 2 of the storage pod design by "Backblaze". In their setup, they have enough pods to provide the required redundancy in case some PSUs bail out - so for them non-redundant PSUs are sufficient.
I've already started to do some reading:
DIY redundant psu... (hardforum.com)
Power Supply System Integration Part 1: Single Source Fault Tolerant Power Systems (powerelectronics.com)
ORing diodes (codemsys.com)
When I found this forum and saw that the site was named "DIY SMPS", I knew I just had to ask here before I make any move
Thank you very much in advance,
^Rooker
^Rooker
