SMPS Failure Analysis and Repair
Hi all,
I'm Nick and this is my first post here. I wound up here while searching and learning about smps.
My application is an inverter tig welder that I managed to blow-up, tried half-jacked repair and duly blew it up again.
After studying and more or less understanding smps designs I am in the process of (hopefully) repairing this welder again.
I will relate what happened first and then add my understanding as to why the welder blew up.
Schems are here,
My welder 160 amp https://dl.dropboxusercontent.com/u/85561940/th160.pdf
Component placing FWIW, https://dl.dropboxusercontent.com/u/85561940/thcomp.pdf
Same welder more less but in 200A version https://dl.dropboxusercontent.com/u/85561940/th200.pdf
The 160A schem (my welder shows 4 IGBT'S (HGTG30N60B3, mine came with 2 of them, HGTG40N60B3 from the factory and it is shown this way in some other docs. Also, my board revision (older) has all the stuff that show as NM, Not Mounted
I live off grid and all my heavy loads and tools run off a diesel generator. Said generator is ex-army issue, twin diesel 6kW single phase. It has always run my heavy loads, welder included w/o problem.
1. First "accident"
I was building some metal door frames and using the welder with a smaller cheesy "5.5 kW Honda clone".
I was only tacking the frames and there was not really any problem. I use the small generator as the big one is 100 feet away and I did not want to always go back and forth to start it or shut it down.
Several days later, after all was tacked, I crank up the welder to do the final welding, forgetting I was still connected to the cheesy generator.
Ater about a second of welding the generator starts modulating from full rpm to almost stalling and I see the digital display of the welder blinking.
I turned it off quickly. I tried again with the same blinking. I plugged into real 230 volts and it went bang.
to be continued....
nick
Hi all,
Schems are here,
1. First "accident"
to be continued....
nick
