SMPS Transformer Primary Turns Calculations
Here some informations about calculating PRIMARY TURNS for SMPS transformer
  • Transformer_Formula.rar
  • Switch Mode Power Supply Transformer Calculations.rar
ravs
hi microsim,
thats only for half bridge .would appreciate if you add information for choosing wire guage for multiple strands to avoid skin effects ie for a given guage using multiple wires of higher guages.post a complete example of smps right from start to end.thanks for sharing
thanks
ravs
be a vegeterian........
Foil
hi microsim,
thanks
ravs
You can use Foil to avoide skin effect at 125KHz as an example, Also if you tel more about the SMPS you want to build, it will be easier to hellp you out :)
lakone
Hi, all. Greeting from me. I'm wondering about the ferrite core that used to be in the PC power supply ( half bridge)?
What kind of ferrite is that? Should I use datasheet from ferroxcube or epcos?
Formula in Excel 2003
can you post the formula file as an "xls" file? some of us are still using MS Excel 2003 :(
Here is the Converted sheet into Excel 2003, Hope it will work with you.
  • 2003Transformer_Formula.rar
soundmax
My Friend MicroSim,
As I had already reviewed it, I'm developing the power switch quasi resonant, but now I have two serious problems:
Its formula can be used with Quasi Resonant power supplies? if so how should I proceed to calculate the inductor and capacitor are in series with the transformer?
I need urgent help from you guys,
awaiting,
a hug to everyone,
Cleber
Resonant
My Friend MicroSim,
awaiting,
a hug to everyone,
Cleber
From my experiance.
Tuning that kind of SMPS, or reaching the resonant is not an easy task.
for me, I have no idea about your SMPS, or even any other details to help you out.
See below formula for calculations
ravs
My Friend MicroSim,
awaiting,
a hug to everyone,
Cleber
hi soundmax,
check this stuffView attachment res1.PDFView attachment res2.PDF
regards
ravs
be a vegeterian....
sphinx
Be mindful of the voltage requirements for the resonant capacitor. I designed a 120/240Vac resonant SMPS with Vin max = 400Vdc due to voltage doubler when configured as 120V AC Input. That required a film capacitor with an AC voltage rating of 650 V. Considering temperature de-rating, a 1KVAC rating was more appropriate. This was not easy to find at a reasonable price so I used two 500Vac capacitors in series.
IGBT
Switching Fanatic!
Pfc
I agree with the capacitor voltage, But where did you get the 400V from? are you using PFC?
sphinx
IGBT, I target high AC line condition at + 20% so:
240VAC + 20% = 288VAC
288 VAC * 1.414 = about 400VDC with diode and in-rush current limiter voltage drops
Cleber,
I used MKP but others are acceptable depending on your particular circuit. Low ESR is obviously preferred.
ravs
hi microsim,
can u post the formula for finding out the secondary turns.for centre tapped winding .i am following marty
browns power supply cookbook and practical switching power supply.both have different calculations.
thanks in advance
ravs
ravs
Here you go with the formula, I know that its not available on the web, even its easy.
Enjoy..
hi microsim,
thanks a lot but can you post the equations involved.i am getting difference in secondary turns.
primary is same as mine.
thanks
ravs
Formula
hi microsim,
thanks
ravs
You have to edit, the fields in the formula * in yellow* to your needs
Ravs
ravs
I see that you are taking too much informations from this site, and acting like you know nothing, while you acting like a professional SMPS guy on other forums, that *I do Hate it* alot.
If you found this place helpful to you, you should mention it there *at least*. other wise it wont be good idea.
Its much better to share here what you are sharing there, or what do you think?
