I am just waiting for my parts to arrive from various sources. In the mean time could someone please help me understand how to wind the main transformer? I have read microsims pdf and also all of this thread but it would help if there were more detailed pictures of how to wind the transformer in a step by step fasion.
Reading the pdf was a bit confusing. Pdf says winding order is half primary," all" secondary, half primary. Then later on it says wind the bobbin using half primary, half secondary, half secondary, half primary?
Also I am not sure what pads to start at and finish at when winding.
I am guessing to starrt winding as follows .:- 1/2 primary:- Start at pad 1-finish-pad 5? When the turns are finished the end of the coil, the wire will be on the opposite end of the transformer. Does this mean the wire has to loop over the whole transformer and then get soldered onto PAD5?
Does this wire then get cut at PAD 5 and a new 1/2 primary get turned from pad 6-finish at pad 10?
Any help to make it easier when starting to wind the transformer would be greatly appreciated as I want to build the transformer properly.
Simon
