Another IR2153 smps
wally7856
Lets say the 3.3v line comes from regulating the 5v line, the 5v line is one winding on the mag amp and the control line is the second. He only had one winding so it had to be an inductor.
Jagd.Panther
I'm kind of lost. 5v line is not a winding on the magmap, it's wound on separate core, it's merely a source of AC (all magamps work on AC).
The control line is a line, not a winding. It's used to reset the magamp core to control the point where the core saturates (and becomes virtually a shor)t. All that is realized with just one winding.
So we have a magamp with one multi-duty winding based on saturable reactor.
bud17
I try buid simple SMPS driver and output connected to bohlamp (AC).
Why all the mosfet always die but IR2153 is running well.
Please help me.
Thank You.
bud17
I update this circuit but all mosfet still is died.
I try to test the IR2153 using LED and resistor with change Rt (2M) and Ct (47nf) the frequency aprox 7Hz and all LED lights FLIP-FLOP.
mone
Error in the library?
I have one question. Is this actually is a mistake connections in my eagle? or yours borysgo2
Jagd.Panther
For operation over 30khz, C1 (C2 on previous schematic) => 0.2-1uF (low ESL, e.g. ceramic), C3 (C6 on previous schematic) => 0.1-0.47 uF (low ESL, e.g. ceramic). Place caps as close to Ir2153 as possible. Do you have a picture of the PCB you used when you have mosfets installed?
bud17
Thank You for your replay.
Ok, next I will attc picture of the PCB with mosfet installed.
I had updated this schema and the mosfets not die again.
But light of the lamp is very poor and all the mosfet is very hot.
When I measure pin 1 Vcc (IR2153) to ground is 14.8 volt.
But when I measure pin 7 to pin 6 the voltage is 4.8volt and pin 5 to ground the voltage is 5.5volt.
And when I measure between plus and minus source, the voltage is 60volt (before it is 310volt)
Please help. (I'm sorry my english is not good)
Thank You.
lynxlynx
A rumbling soft motor
Thank You.
If you're measuring with regular multimeter then it's fine, such measurements show only average voltage if IR2153 outputs with almost full 50% duty. If you have your fets heating then you need to check the gate waveform somehow (with oscilloscope)...
lynxlynx
Here is the picture mosfets installed.
The lamp's light still poor and mosfet very-very hot.
Thank You.
Also try to measure not pin7 to pin6, but high gate to pin6 and not pin5 to gnd but low gate to gnd (or measure voltage across gate resistor). Maybe you'd just picked up wrong part.
To avoid loosing mosfets I would attach a small heatsink to them (with insulation pads of course).
res_smps
1. your chip marking different from datasheet, i am not sure if it is genuine
2. lamp will not light brightly compared with directly connected to 220 line, because violtage at the lamp only 155v square wave (77v average or less measured with voktmeter)
Jagd.Panther
Can you please attach picture of the bottom side? Do you have an oscilloscope?
anyway, if you are using IRF740 and the switching frequency ~50 kHz, I suggest you to increase gate resistor to 50-100 ohm. BTW Did you install ceramic caps like I mentioned?
Also if you have installed 1k resistors across the gate-source, changed them to 10k or so.
bud17
Thank you for your replay.
Here is picture of bottom side and when this driver circuite running.
Unfortunately I still do not have an oscilloscope.
Now I am using IRF840 (after try to use IRF740 with the same result) with 10 ohm resistor on the gate.
Yes, I installed ceramic capasitor for Ct (IR2153).
And between gate-source I installed 10K resistor.
borysgo2
I have done some further work on the protection with IR2153, I think I know why so often it just sucks. If you are using open collector transistor or triac or mosfet to pull down Ct pin to GND make sure it is done very quick, otherwise your mosfets will be gone for sure. While pulling the Ct pin to GND the width of the ON/OFF ratio is changed and the frequency is changed too. So if you are just at about max load (let me say 5%) and you increase the load a further bit Ct pin might be not fully pulled down.
The IR2153 have UV detection and small mosfet build in, I have tryed to pull down Vcc voltage and it works perfect. So from practical point of view it is way easier to use Vcc pull down instead Ct pull down.
Hopefully it will help a bit.
borysgo2
Small update.
I have removed the current sense trafo and used instead capactive divider, it works perfect. The SMPS is very quiet at over load (no buzzz or hiss noises), the setup is dead simple and works perfect. The dynamics of the protection can be easily seated up with a few capacitors.
