i used a ferrite core, similar size to T106 iron toroid. you can refer to T106 toroid spec for the size.Hi Paskal what type of inductor have you used?
yes, we tried lots of bass heavy scene and for prolonged period of time. i reckon around a couple of hours of test. the test are done in elevated level which i will never (ever) listen at my home. and we only tried specific scenes with lots of low frequency <20Hz.thanks paskal i will upload my photos too . is the amp still working and did you drive hard for a long time with 2 ohms did the outputs get hot or they were manageable?
good to study, however toroidal core with gap is expensiver.
good technical, we also often open air gap for power core(Mn-Zn) for DC current requirement,howeve air gap dimension must be accurate.
are those really ferrite core? read from somewhere before that if it's ferrite than it doesn't really matter what type they are as long as they're ferrite. just make a gap in them to avoid saturation and measure the inductance. well that's what i read from a guide downloaded somewhere regarding the use of ferrite core for class d switching amp.Hi,
Is there a short circuit protect in this amp? Anyone tried it?
I have these ferrite toroid here, do I have to make a small gap or I'll just stack the two together to avoid heating? (like in the picture)
Thanks,
FT-87A Ferrite toroid
norazmi is busy with work. he told me that he'll be back to the forum once he get everything sorted out at work.hi Norazmi where you go no signs of you visiting the forums hope everythings OK
warm regards
michelle
yes. my ferrite also attracted to magnet.Do ferrite cores also attracted to magnets? because I tried placing magnet on my "green toroid" above and the magnet sticks to it.
what type of inductor that you used? how much inductance? from my test the simple class d and tl074 non-ucd are not stable with low inductance. they tend to go unstable even with 20uH. better to have them running with above 30uh.hi guys this amp is amazing . but it failed after 20 mins pushing it hard with a kenwood 4 ohms 12inch subwoofer . the mid channel was o.k .
>>> the output fets i used were irf9530 and irf540 my voltage was +/- 35vlts dc
what can be the issue ? because in previous posts norazmi drove his amp with 2ohms for about a whole night.
