I just follow Acca.
That is the best choice how build prototype.. Easy for modification if any mistake. :adoration:
@Acca, i will increase primer BDT to 8 Turns. Can we are increase frequency to 50Khz? If can, where need modification?
You can try.... If something get wrong,you will hear it,freq will be low if core is not adequate...acca can i use the small black ferite from a pc psu for base driver?
CFL BDT has high perm. too....No, because the black ferrite from a PC is Filter with high permeability.
no...
it doesn't work....
i have 51 volt at the outpout(the voltage is corect) but when i conect a 3amp load the voltage drops to 10 volts....
47 ohm feedback resistor is too hot.....
i have use 2watt resistor...
my outpout coil is an ei33 transformer with 28 turns ...
and i aded a 2.7 ohm resistor at the bases of the transistors...(13007)
what causes this problem?
I say to use 2W ones.
