badboy_6120
Can you introduce a good and reliable way for applying transformer overheat protection?If you don't have thermal shutdown/trafo overheat protection then I'd measure at highest possible mains voltage (265 VAC for 230+-15%)
A bimetal switch like that:Can you introduce a good and reliable way for applying transformer overheat protection?
https://www.google.com/search?num=3....5.0....0...1c.1.64.serp..3.4.692.PGqLOaeWFe4
taped or glued to the hottest part of the transfromer. If you are cooling the transformer with a fan the thermoswitch should be from the opposite side, so it's not cooled by the fan.
How was the core cooled? Convection cooled or forced cooled with a fan?Hi everyone
I wound the primary test winding with 10-12-14-16-18-20 turns one after another and measured the cores temperature in idle condition as below:
10 turns: after 1 hour=87°c
12 turns: after 1 hour=79°c
14 turns: after 1 hour=70°c
16 turns: after 1 hour=60°c
18 turns: after 1 hour=53°c
20 turns: after 1 hour=46°c
room temperature was in the range of 27°c to 30°c
Do you mean one half (E-shaped) was hotter than other one?and another thing, one side of cores was less hotter than the other side (about 10°c)
I'd go with 18 (or even 16) for forced cooled transformer and with 20 turns otherwise.**above temperatures are measured from the most hottest point of transformer cores**
**frequency in above measurements was set to 70khz**
should I go with 18 turns or 20???
I didn't use any cooling method in my measurementsHow was the core cooled? Convection cooled or forced cooled with a fan?
No, I meant the sides that consist of two legs of coresDo you mean one half (E-shaped) was hotter than other one?
Do you have any picture that shows how to apply force cooling to transformer??I'd go with 18 (or even 16) for forced cooled transformer and with 20 turns otherwise.
@badboy
Try running your SMPS at 125Khz, and measure the heat of the ETD49 core in idle.
Let me know results
Let me know results
59°c in more than one hour in room temp of 28°c
**Primary turn= 22
I don't suppose you are ready to try what i told you to do 3 days ago. 25 to 30khz.
Are you using original CORES?
In post 17 you said you had MF102 ferrite material, now in post 54 you say you have 6H20 material. Do you have two different cores?
What is your measured AC input voltage?
badboy i am trying to work out what you have. Do you have an official winding width for your bobbin. I want to know how many primary turns can fit on one layer. You may know this from your experimenting.
