vacuum tube smsp
eonscom
Hi
I am going to make smps to apply to vacuum tube amplifiers.
So far, the sg3525 and ir2110 have been used to produce more than 450V 1A, but there are many defects.
I want to hear advice from an expert.
eonscom
tube smps circuit
This is the schematic I made.
Check if there is a problem with the circuit.
  • SMPS-V2.pdf
Active member
Do you intend to regulate the output voltage?
Did you check the dead time on the gates?
What current draw is there on the HV output?
What is the value of the output inductor?
eonscom
The output voltage only applies to rectified
I am looking for a way to adjust the voltage
There is enough dead time.
I applied a 100 ohm resistor and there was no problem when viewed on a scope
Not HV
It is the power to heat HT tube heater
Without vacuuming the tube heater power to dc
Directly apply high-frequency power to heat
It was manually wound on the ring core
I do not know exactly what Henry is.
See photos
Active member
If your maximum current lies on the tube heaters then you can sample the output voltage there. You can rectify the voltage only for sample. you can still feed the heater AC.
The output inductor value is chosen according to the current it is going to handle. If the current is small then the value of the inductor rises.
A feedback loop can be done with the heater voltage and regulate the pulse width to stabilize the output voltage.
Something about the circuit. I see no snubber on the primary of the transformer. How pure are your wave forms at load?
eonscom
The problem is the transformer.
Bifilar winding of coil to rectify by center tap method
I changed the end and made the final.
Even though there is no load, the coil gets hot.
I do not know what went wrong.
Applied Trans: ETD49
Primary: 0.45mm X 5 - 22 TURN
Secondary: 0.32mm X 2 X 2 - 70 TURN : 450 V expected
Active member
Be very careful when winding the secondary. Do not forget that a square wave tend to have a lot of harmonics and also tend to generate spikes. Spikes can also lead to high voltages and can be multiplied in the secondary windings by the turns ratio. (high voltage can arc and destroy the insulation and thus having shorted turns)
In your case this must be the cause of the secondary winding heating up.
Turns ratio look good and at 220vac you should have around 490v on the secondary when smoothed with the output capacitor. ( if you have spikes in the primary this can rise to over a 1000v)
I suggest:-
1) You insert a snubber across the primary winding this will suppress any spikes as the mosfet switches off.
2) Post a scope shot of the waveform across the primary winding.
3) Read this blog post and download the PDF. You will learn about winding practices.
The link is here http://www.diysmps.com/forums/entry.php?143-Transformer-winding-practices-for-smps
4) Rewind your transformer in the way explained by the PDF file.
5) It will help a lot if you leave some space on the bobbin cheeks with the winding. Put a layer of Maylar tape between each winding layer.
6) Take measurement of the input current and let me know what is it, If you have a watt meter it is better.
Generating that number of output voltages with that PCB is a huge challenge.
I also don't understand your idea behind the variable output voltages, i don't see a regulator.
I think more work is needed to achieve your goal
eonscom
The current image smps is rectified to about 315v and is used as the B + voltage of the tube amplifier
HER 508 4 diodes are used by bridge rectification.
Primary: 0.85mm X 1 - 40 TURN
Secondary: 0.32mm X 3 - 86 TURN : 315 V
When applied to the above specifications, the output waveform has a lot of ringing and noise.
I am making a new transformer to apply the center tap method.
Excellent -SMPS Transfomer Tool Data
Active member
Probe the primary winding. and see if the ringing is present at the primary. If it is there then you have to put a 470pf cap in series with a 3 watt 47 ohm resistor across the primary to suppress spikes and ringing.
The pictures you posted of the tool data is too small to see it. Take picture with mobile or camera of computer screen and upload that.
The primary of the transformer turns seems a little too much. I do not know your switching frequency and also the core material. Please give the details and I will help you out with your calculation.
1 core material
2 switching frequency
3 input ac voltage at your house
4 heater voltage and current
5 Max plate DC voltage
6 Bias maximum DC voltage
eonscom
1 core material
-I do not know the exact specifications.
But size is the same (etd49)
- 50kHz (variable) 30~80Khz
AC 215 V
300B : 5V 1.5A X 2EA : #18 WIRE 2TURN (6.7V Down by resistance)
6SN7 : 6.3V 0.5A X 2EA : #18 WIRE 2 TURN
50KHz AC DIRECT HEATING
MAX : 420V
MAX : 90V
Active member
Hi Eonscom, I have made some calculations for you. As for the core material I chose N27 which is not so high permeability as the core you are using is not known.
Here are the results
Note 1)
Wire size is 0.5mm This wire can handle the frequency of 60Khz. If you make thicker wire it will be in vain as the current tend to travel on the outer skin at high frequencies and the extra thickness will not be used. However you can use multiple wires together (twisted or side by side) In your case 3 wires by 0.5mm for the primary. Choose the best fit for a single layer. Either 3 wires side by side or 3 wires twisted together.
Note 2)
See if you can sandwich the secondary windings between the primary. Make half primary turns then secondary turns then half primary on top. Leave the heater windings for last on the very top. That is on top of the last primary winding. the heater windings are not so important.
Note 3)
Try to cover the whole bobin with each layer of winding. Leave 3mm margin space at the ends of the bobbin for safety. Use mylar tape this tape is high temperature and very thin. Use 3 layer of this tape to isolate the primary winding from the secondary. Use one layer of tape between each secondary winding layer so that you can see better what you are doing.
Note 4)
The voltages used are made such as the amplitude of the rectified and smoothed voltage will rise to the peak. If you notice the 2nd picture you will see what Mean. Please also note that the voltage will sag down with load as the smps is not regulated.
Switching frequency 60Khz
Primary turns 22 turns (3 wires X 0.5mm)
Plate secondary voltage turns 65. (0.5mm x 1) ( peak voltage 427v at 215vac input)
bluetooth aux 15-0-15 3+3 turns (0.5mm X 1) use 2 wires together and start from center tap. put ends on each side on pins.
Bias voltage 13 turns (0.3 x1) Peak voltage 85v at 215vac input
Heater voltage 2 turns (6.3v) 0.5mm X 1
Heater voltage 2 turns (5v) 0.5 mm X 2
  • EONSCOM.pdf
Active member
Hi Eonscom,
One last note if you want to make adjustment just calculate that you have 7 volts per turn. 155v / 22 turns pri =7v per turn
eonscom
Thank you for your quick reply.
The above specs were first attempted and have problems.
Currently in production
The problem is trying to apply the center tap method rather than the bridge rectification method
Primary: (0.45x5) x 22 turn
Secondary: # 18wirre 1 turn: Normal output waveform (6.73V)
It is confirmed to be normal for testing
There is no problem in applying 420V winding to 80 turns
Further winding of 80turn will cause the coil to heat up even though there is no load
test: # 18 Wire 1turn: Output Waveform Distortion (5.8V)
Active member
Regarding rectification well the bridge requires one winding while center tap requires two windings.
One tip for you if you want to make a center tap winding.
wind two wires at the same time. You start at the center tap. you finish with two wires each wire will be a separate winding.
This method will help to have balance windings with equal voltages.
I do not recommend that you make center tap winding for the high voltage side, It is the way you are winding it. Leave margin space at the ends like 4mm on each side and put a layer of tape between each layer of winding. Do not use masking tape it is not good for this work.
Remember that square wave tend to have spikes and easily breaks insulation at high voltage.
The distortion in the waveform is intermittent and not constant. try to twist the ends of the one turn loop and measure again
Active member
May I ask where are you going to take the sample voltage for the regulation of the output voltage?
I see you opted yes for regulation in Excellent IT software
Remember that the software is suggesting the inductor value. This value will grow with minimum current for each winding. the lower the higher the inductance. If the plate voltage has a constant load then it will be right to put the right current in the software. Please note that if you are not regulating the output you do not need the inductor or it could be very small.
The snubber resistor you are using is too high. Try like 100 ohms at least, or lower. It could be down to 10 ohms
read this article about snubber. download the pdf.
http://www.diysmps.com/forums/entry...-snubber-components-and-driver-gate-resistors
eonscom
I tried it. However, when I switched on, the protective 100W bulb turned on because of the overcurrent.
I have wound several windings, but more than 400v (only 64 turn) is not a problem with single windings.
If you turn 128 times in center tap mode, the coil is very hot even if there is no load.
eonscom
I've tried a few, but the best way is
The windings are divided into two areas.
  • coil-v1.pdf
