@ kaip
attached is the FULL circuit, with missing critical part values, some of them
Please be serious, and make this project available to the DIY, some on in the past tried to do it, then he stole the design.
So I expect nice results from you
You have to make INPUT CARD PCB
And power boards
I dont know about the limiter section where you plan to put it
we can discuss
thanks
You are so close to start PM
make some posts in the forums, try to answer some other topics, and you will be free to go, this way we make sure that every one here is for share, not only taking things
Heres another post !
I have the schematic. It is big indeed !
Will have a good look at it now...
It might be a bit ambitious but it should be doable with some changes to make it DIY friendly.
SMD parts should be avoided. Same for difficult/ exotic/ hard to get parts.
The biggest challenge is probably the earthing. There are at least four different earths.
As I see it now there should be 4 separate modules:
- Power amp(s)
- Input/Compression
- Power supply
- Front panel / Display
Here is the first "module" to check.
Microsim : I cannot easlily remove what you requested. Maybe you can ?
When I have enough post I will mail them to you first and you can upload them.
