IGBT
Switching Fanatic!
Smps
Ludo
its long time, are you going to show the final files or what?
I am waiting you to show them, because I would like to build one for my amplifier R#:
ludo3232
Hi all,
i post the final files. :D
  • smps v2.1 PCB.pdf
  • smps v2.1 Parts.pdf
kubeek
It looks like you did it in Eagle, could you post the eagle files as well, because I would like to use it in a little different design..
The copper shield in that transformer is a "free" turn of copper foil? Where is it connected to?
terminaterx300
Me too, I'm using a CNC Router to make pcb so could u post ur eagle file or gerber file of it
SMPS Files
Lets make things clear..
We have found *as per the link below* that Ludos and diysmps hard work has been stolen.
http://www.forosdeelectronica.com/f21/smps-half-bridge-mini-ir2153-pcb-48435/index2.html
POST28
If you check that link, you will see a guy who posted ALL the files of the SMPS (IR2153D Version) on other forums, claiming things
We dont have a problem into that at all, because its DIY and for DIY, but at least mention our name and Ludos Name.
Thats why Ludo WILL NOT post original EAGLE files
There is a schematic and PCB layout and ALL informations you need, and HELP
that will make your SMPS work in very short time, if you need Eagle file, its very simple to Re Draw the whole thing from Zero!
Hope thats fair for all
Thanks for understanding
michelle
hi ludo
greetings nice project for all smps fans lot of hard work you have put in this wonderful project thanks you and sir microsim since transformer
is the most critical part in this project is it possible to show a small vedio how the winding of transformer is done for diyers to make at home
thanking you
michelle sir i have changed my internet provider due to slow speed hope this is not a problem for DIYSMPS
@michelle
I will make a PDF file on how to wind the transformer, its very easy. and I mean it, very easy
This SMPS are not like other at the web, this SMPS for REAL power.
@terminaterx300
Show me picture of your machine, I am interested. I am not sure if ludo will show gerbers.
Why dont you make the PCBs like in the old way?
Regarding your EI38-1 transformer, I need more info about it to tell you windings
Thanks for all
vikramjoshi
Hello MicrosiM ,
These files are enough to make a pcb. I will start the build in few days.
As this is my first experience in making a Smps, i want to ask where does transformer fit in this pcb.
Thank you.
Hello MicrosiM ,
Thank you.
Hello vikramjoshi
Thanks for the intrest into making this SMPS unit.
There is big square on the PCB, Marked ETD49. that is the transformer we have used there
Transformer Winding Instructions
Attached is Transformer Winding Instructions
Its very easy.
For all who will start making this SMPS, PLEASE
If you need ANY help, ANY help
Dont hesitate to ASK what ever you want, Asking now will save you time later.
This SMPS is fully working, Ludo will post more results soon
  • SMPS_Transformer_Winding.pdf
ludo3232
SMPS testing with audio amplifier...
[video=youtube;XuBwE6fqU6A]http://www.youtube.com/watch?v=XuBwE6fqU6A[/video]
Sierra
Valve Lover!
Ludo3232
That small card is not mentioned into your schematics, What is it?
Lot of things are hidden also, values are mixed upon each other on schematics
PLEASE submit a complete schematics
otherwise we cant make this SMPS
Thank you for hard work
terminaterx300
@terminaterx300
Thanks for all
this is my pcb from my cnc
about EI38-1 transformer, i think it is a ready to use sealed transformer. ETD49 i cound get it but EI38-1 is big trouble.
Cnc
I am afraid that you cannot use this method to make the SMPS PCB
Due safety issues, creepage, clearances
PLEASE make it as it is, not using CNC
use old way of making this PCB please
terminaterx300
Microsim, can´t you see that white PCB which is milled and has large clearances?
creepage or clearances is about what kind of pcb.top pcb is large clearance.
I can make pcb exactly same as old way
p/s BTW i must redraw this board :(:( , it will take me a long time
Cnc
@kubkee I think you are right
I never used that CNC thing, I thought he cant make clearances !!!:
@terminaterx300
I advice you to make the PCB using film coated PCBs
or it looks that it will take you very long time
