It looks like you did it in Eagle, could you post the eagle files as well, because I would like to use it in a little different design..
The copper shield in that transformer is a "free" turn of copper foil? Where is it connected to?
Hello MicrosiM ,
These files are enough to make a pcb. I will start the build in few days.
As this is my first experience in making a Smps, i want to ask where does transformer fit in this pcb.
Thank you.
@terminaterx300
Show me picture of your machine, I am interested. I am not sure if ludo will show gerbers.
Why dont you make the PCBs like in the old way?
Regarding your EI38-1 transformer, I need more info about it to tell you windings
Thanks for all
I am afraid that you cannot use this method to make the SMPS PCB
Due safety issues, creepage, clearances
PLEASE make it as it is, not using CNC
use old way of making this PCB please
Microsim, can´t you see that white PCB which is milled and has large clearances?
